Ana içeriğe geç
Samsung Chromebook series 5 XE550C22 SSD Replacement
Neye ihtiyacın var
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: adım 1, 3 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: adım 1, 3 resimden 2. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 2, 2 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 2, 2 resimden 2.
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 3, 3 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 3, 3 resimden 2. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 3, 3 resimden 3.
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 4, 2 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 4, 2 resimden 2.
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: adım 5, 2 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 6, 2 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 6, 2 resimden 2.
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: adım 7, 1 resimden 1.
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 8, 3 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 8, 3 resimden 2. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 8, 3 resimden 3.
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 9, 2 resimden 1. Samsung Chromebook series 5 XE550C22 SSD Replacement: adım 9, 2 resimden 2.
    • Pull the SSD up and away from the Chromebook
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abel Osorio
330 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G7
3 Üyeler
14 adet Kılavuz yazıldı
4 Yorum
Hello where can I get I higher SSD to buy
aduboa moses - Yanıt
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - Yanıt
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - Yanıt
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 5,063
