Ana içeriğe geç
Samsung DV180F Repair Back control buttons Replacement
Neye ihtiyacın var
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: adım 1, 2 resimden 1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: adım 1, 2 resimden 2.
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: adım 3, 1 resimden 1.
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: adım 4, 2 resimden 1. Samsung DV180F Repair Back control buttons Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: adım 5, 1 resimden 1.
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: adım 6, 2 resimden 1. Samsung DV180F Repair Back control buttons Replacement: adım 6, 2 resimden 2.
    • Remove back display.
    • Replace the back button panel.
Sonuç
maria
244 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 365
