Ana içeriğe geç
Samsung DV180F Repair Battery Replacement
Neye ihtiyacın var
  1. Samsung DV180F Repair Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung DV180F Repair Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: adım 2, 1 resimden 1.
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: adım 3, 2 resimden 1. Samsung DV180F Repair Battery Replacement: adım 3, 2 resimden 2.
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: adım 4, 1 resimden 1.
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
Sonuç
maria
250 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 466
