Ana içeriğe geç
Samsung DV300F Lens Replacement
Neye ihtiyacın var
    1. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 1. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 2. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 3.
      • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung DV300F Lens Replacement: adım 2, 2 resimden 1. Samsung DV300F Lens Replacement: adım 2, 2 resimden 2.
      • Remove the back case of the camera carefully.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung DV300F Lens Replacement: adım 3, 3 resimden 1. Samsung DV300F Lens Replacement: adım 3, 3 resimden 2. Samsung DV300F Lens Replacement: adım 3, 3 resimden 3.
      • Remove the front case of the camera.
      • Remove the front LCD screen from the front case next to the lens.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung DV300F Lens Replacement, Back Button Control: adım 4, 2 resimden 1. Samsung DV300F Lens Replacement, Back Button Control: adım 4, 2 resimden 2.
      • Remove the blue button control from its position next to the LCD screen.
      • Pull the ribbon cable to disconnect the blue button control from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung DV300F Lens Replacement, Back LCD Screen: adım 5, 1 resimden 1.
      • Remove the back LCD screen from its place carefully.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung DV300F Lens Replacement: adım 6, 2 resimden 1. Samsung DV300F Lens Replacement: adım 6, 2 resimden 2.
      • Flip the black tab where the back LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the back LCD screen from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung DV300F Lens Replacement, Lens: adım 7, 2 resimden 1. Samsung DV300F Lens Replacement, Lens: adım 7, 2 resimden 2.
      • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
      • Remove the circuit board cover
      FixBot'a Sor
      Yorum Ekle
    2. Samsung DV300F Lens Replacement: adım 8, 2 resimden 1. Samsung DV300F Lens Replacement: adım 8, 2 resimden 2.
      • Flip the first black tab connecting the lens to the circuit board
      • Flip the second black tab connecting the lens to the circuit board
      • Push the lens out from the front to remove it from the camera
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Timothy Gordon
874 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-10, Williams Spring 2015 Baylor, Team 5-10, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G10
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 66
Her zaman: 3,371
