Ana içeriğe geç
Samsung DV300F Lens Replacement
Neye ihtiyacın var
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 1. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 2. Samsung DV300F Lens Replacement, Front and Rear Casing: adım 1, 3 resimden 3.
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: adım 2, 2 resimden 1. Samsung DV300F Lens Replacement: adım 2, 2 resimden 2.
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: adım 3, 3 resimden 1. Samsung DV300F Lens Replacement: adım 3, 3 resimden 2. Samsung DV300F Lens Replacement: adım 3, 3 resimden 3.
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: adım 4, 2 resimden 1. Samsung DV300F Lens Replacement, Back Button Control: adım 4, 2 resimden 2.
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: adım 5, 1 resimden 1.
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: adım 6, 2 resimden 1. Samsung DV300F Lens Replacement: adım 6, 2 resimden 2.
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: adım 7, 2 resimden 1. Samsung DV300F Lens Replacement, Lens: adım 7, 2 resimden 2.
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: adım 8, 2 resimden 1. Samsung DV300F Lens Replacement: adım 8, 2 resimden 2.
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Timothy Gordon
820 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-10, Williams Spring 2015 Baylor, Team 5-10, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G10
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 2,048
