Ana içeriğe geç
Samsung DVD-HD850 Player Cover Replacement
Neye ihtiyacın var
  1. Samsung DVD-HD850 Player Cover Replacement, Cover: adım 1, 1 resimden 1.
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Cover Replacement, Locate and remove screws: adım 2, 1 resimden 1.
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Cover Replacement, Remove Cover: adım 3, 1 resimden 1.
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Sonuç
Bir başkası bu kılavuzu tamamladı.
Devon Clements
228 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G6
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 364
