Neye ihtiyacın var
with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
locate the three (3) screws on the back panel of the device that are implanted in the device
to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
As noted by the red circles, locate and remove the screws one at a time
After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
Unscrew the one screw that is connecting the circuit board to the frame.
Jiggle the circuit board until it becomes loose from the two prongs holding it in place.
Replace with a new one.
