Ana içeriğe geç
Samsung DVD-P230 Tray Motor Replacement
Neye ihtiyacın var
  1. Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: adım 1, 3 resimden 1. Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: adım 1, 3 resimden 2. Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: adım 1, 3 resimden 3.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Samsung DVD-P230 Tray Motor Replacement: adım 2, 1 resimden 1.
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Samsung DVD-P230 Tray Motor Replacement: adım 3, 1 resimden 1.
    • Unscrew the 3 screws in the back.
  4. Samsung DVD-P230 Tray Motor Replacement: adım 4, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 4, 2 resimden 2.
    • Pull the outer case upward and then towards you.
  5. Samsung DVD-P230 Tray Motor Replacement: adım 5, 3 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 5, 3 resimden 2. Samsung DVD-P230 Tray Motor Replacement: adım 5, 3 resimden 3.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Samsung DVD-P230 Tray Motor Replacement: adım 6, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 6, 2 resimden 2.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Samsung DVD-P230 Tray Motor Replacement, Power Cord: adım 7, 3 resimden 1. Samsung DVD-P230 Tray Motor Replacement, Power Cord: adım 7, 3 resimden 2. Samsung DVD-P230 Tray Motor Replacement, Power Cord: adım 7, 3 resimden 3.
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Samsung DVD-P230 Tray Motor Replacement, Tray: adım 8, 3 resimden 1. Samsung DVD-P230 Tray Motor Replacement, Tray: adım 8, 3 resimden 2. Samsung DVD-P230 Tray Motor Replacement, Tray: adım 8, 3 resimden 3.
    • Remove the three screws holding in the DVD tray
  9. Samsung DVD-P230 Tray Motor Replacement: adım 9, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 9, 2 resimden 2.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Samsung DVD-P230 Tray Motor Replacement: adım 10, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 10, 2 resimden 2.
    • Gently lift the DVD tray off of the motherboard.
  11. Samsung DVD-P230 Tray Motor Replacement, Tray Motor: adım 11, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement, Tray Motor: adım 11, 2 resimden 2.
    • Spin the small gear shown to the right to begin opening the tray. There should be relatively little resistance in the gear.
  12. Samsung DVD-P230 Tray Motor Replacement: adım 12, 3 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 12, 3 resimden 2. Samsung DVD-P230 Tray Motor Replacement: adım 12, 3 resimden 3.
    • Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
  13. Samsung DVD-P230 Tray Motor Replacement: adım 13, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 13, 2 resimden 2.
    • In order to remove the tray motor you must detach the small rubber band that runs between the two shown wheels.
    • If the rubber band is improperly fitted onto one of the wheels or broken this is probably the cause of the tray not opening or closing.
  14. Samsung DVD-P230 Tray Motor Replacement: adım 14, 2 resimden 1. Samsung DVD-P230 Tray Motor Replacement: adım 14, 2 resimden 2.
    • Flip over the tray.
    • Unscrew the two screws that attach the motor to the tray.
    • Once completed the motor can be easily removed and replaced.
Sonuç
Mitchell Hart
903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G30
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 13
Her zaman: 5,035
