Ana içeriğe geç
Samsung Droid Charge SIM Card Port Replacement
Neye ihtiyacın var
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: adım 2, 1 resimden 1.
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: adım 3, 1 resimden 1.
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: adım 4, 1 resimden 1.
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: adım 5, 1 resimden 1.
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
  6. Samsung Droid Charge SIM Card Port Replacement: adım 6, 1 resimden 1.
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge SIM Card Port Replacement: adım 7, 1 resimden 1.
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
  8. Samsung Droid Charge SIM Card Port Replacement: adım 8, 2 resimden 1. Samsung Droid Charge SIM Card Port Replacement: adım 8, 2 resimden 2.
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lucas Carter
172 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G44
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 2,526
