Ana içeriğe geç
Samsung Droid Charge Screen Replacement
Neye ihtiyacın var
    1. Samsung Droid Charge Screen Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Open up the back case on the phone from the groove in the bottom of the phone.
      • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Droid Charge Screen Replacement, Battery: adım 2, 1 resimden 1.
      • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
      • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Droid Charge Screen Replacement, microSD: adım 3, 1 resimden 1.
      • Push the SD card further into its metal slot until you hear a click.
      • Release the card, and it should automatically eject itself.
      • Remove the SD card.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Droid Charge Screen Replacement, SIM Card: adım 4, 1 resimden 1.
      • Slide the SIM card out of its casing by pushing on it and sliding it upward.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Droid Charge Screen Replacement, Screen: adım 5, 1 resimden 1.
      • Locate the 7 small black screws located around the edge of the phone under the battery cover.
      • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Droid Charge Screen Replacement: adım 6, 1 resimden 1.
      • Locate your pry tool.
      • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
      • Use a prying motion to lift the casing up.
      • Repeat this motion all around the screen edge until the casing pops off.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Droid Charge Screen Replacement: adım 7, 1 resimden 1.
      • Release the one pop connector for the motherboard located on the right.
      • Release the volume button flex cable on the right.
      • Release the power button flex cable on the right.
      • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Droid Charge Screen Replacement: adım 8, 3 resimden 1. Samsung Droid Charge Screen Replacement: adım 8, 3 resimden 2. Samsung Droid Charge Screen Replacement: adım 8, 3 resimden 3.
      • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
      • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
      • Work carefully to prevent damage to the phone.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Droid Charge Screen Replacement: adım 9, 1 resimden 1.
      • You can now swap out the old screen for your new one.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Luke Gordon
199 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G44
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 3,480
