Ana içeriğe geç
Samsung Epic 4G Power Button Replacement
Neye ihtiyacın var
  1. Samsung Epic 4G Power Button Replacement, Phone Case: adım 1, 1 resimden 1.
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Epic 4G Power Button Replacement: adım 2, 1 resimden 1.
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Epic 4G Power Button Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the battery from the device by pulling the battery edge upwards.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: adım 4, 1 resimden 1.
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: adım 5, 2 resimden 1. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: adım 5, 2 resimden 2.
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: adım 6, 2 resimden 1. Samsung Epic 4G Power Button Replacement, Removing the Power Button: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Cunningham
273 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G25
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 2,758
