Ana içeriğe geç
Samsung Epic 4G Power Button Replacement
Neye ihtiyacın var
  1. Samsung Epic 4G Power Button Replacement, Phone Case: adım 1, 1 resimden 1.
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: adım 2, 1 resimden 1.
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: adım 4, 1 resimden 1.
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: adım 5, 2 resimden 1. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: adım 5, 2 resimden 2.
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: adım 6, 2 resimden 1. Samsung Epic 4G Power Button Replacement, Removing the Power Button: adım 6, 2 resimden 2.
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Cunningham
273 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G25
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,270
