Giriş
Use this guide to replace the headphone jack/vibrator.
Parçalar
Hiçbir parçaya gerek yok.
Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
Push the plastic opening tool downward to pry the battery up from its housing.
Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
Insert the sharp end of a spudger into the gap in the corner of the midframe to free the vibrator from the adhesive.
7 başka kişi bu kılavuzu tamamladı.
