Ana içeriğe geç
Samsung Epic 4G Touch microSD Card Replacement
Neye ihtiyacın var
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: adım 1, 2 resimden 2.
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: adım 2, 2 resimden 1. Samsung Epic 4G Touch microSD Card Replacement: adım 2, 2 resimden 2.
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: adım 3, 2 resimden 1. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: adım 3, 2 resimden 2.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: adım 4, 1 resimden 1.
    • Pull the microSD card away from its slot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Uhh.... my Australian SGSII looks different to this...
Bonj - Yanıt
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 4,356
