Ana içeriğe geç
Giriş
Use this guide to replace the microSD card.
Parçalar
Hiçbir parça belirtilmedi.
  1. Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack. Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Lift and remove the rear case. Lift and remove the rear case.
    • Lift and remove the rear case.
  3. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Pull the microSD card away from its slot.
    • Pull the microSD card away from its slot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Uhh.... my Australian SGSII looks different to this...
Bonj - Yanıt
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 4,141
