Ana içeriğe geç
Samsung Epix Keyboard Replacement
Neye ihtiyacın var
    1. Samsung Epix Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Epix Keyboard Replacement: adım 2, 1 resimden 1.
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Epix Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
      • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
      • Be gentle
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Epix Keyboard Replacement: adım 4, 1 resimden 1.
      • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
      • Three of the screws are evenly spaced on the left and right side on the back of the phone.
      • The upper right screw is 4.5mm while the rest are 6.5mm.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Epix Keyboard Replacement: adım 5, 2 resimden 1. Samsung Epix Keyboard Replacement: adım 5, 2 resimden 2.
      • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
      • There are three clips on each side and two at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Epix Keyboard Replacement: adım 6, 1 resimden 1.
      • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
      • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Epix Keyboard Replacement: adım 7, 1 resimden 1.
      • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
      • Carefully disconnect the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Epix Keyboard Replacement: adım 8, 1 resimden 1.
      • Gently lift and remove the front faceplate
      • Exercise caution
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Epix Keyboard Replacement: adım 9, 1 resimden 1.
      • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
      • Lift it and gently take it out the frame to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris
32 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G15
5 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 2,070
