Ana içeriğe geç
Samsung Epix Keyboard Replacement
Neye ihtiyacın var
  1. Samsung Epix Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Keyboard Replacement: adım 2, 1 resimden 1.
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Keyboard Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: adım 5, 2 resimden 1. Samsung Epix Keyboard Replacement: adım 5, 2 resimden 2.
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: adım 6, 1 resimden 1.
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: adım 7, 1 resimden 1.
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Samsung Epix Keyboard Replacement: adım 8, 1 resimden 1.
    • Remove the front faceplate.
  9. Samsung Epix Keyboard Replacement: adım 9, 1 resimden 1.
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris
23 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G15
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,642
