Ana içeriğe geç
Samsung Epix LCD Display Replacement
Neye ihtiyacın var
  1. Samsung Epix LCD Display Replacement, Battery: adım 1, 1 resimden 1.
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix LCD Display Replacement: adım 2, 1 resimden 1.
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix LCD Display Replacement, LCD Display: adım 3, 1 resimden 1.
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: adım 5, 2 resimden 1. Samsung Epix LCD Display Replacement: adım 5, 2 resimden 2.
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: adım 6, 1 resimden 1.
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: adım 7, 1 resimden 1.
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: adım 8, 1 resimden 1.
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: adım 9, 1 resimden 1.
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: adım 10, 1 resimden 1.
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: adım 11, 1 resimden 1.
    • Lift the LCD display out from phone chassis.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mark Wyse
62 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G15
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,000
