Ana içeriğe geç
Samsung Epix Motherboard Replacement
Neye ihtiyacın var
    1. Samsung Epix Motherboard Replacement, Battery: adım 1, 1 resimden 1.
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Epix Motherboard Replacement: adım 2, 1 resimden 1.
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Epix Motherboard Replacement, Speakers: adım 3, 1 resimden 1.
      • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Epix Motherboard Replacement: adım 4, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
      • The upper right screw is 4.5mm while the rest are 6.5mm.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Epix Motherboard Replacement: adım 5, 2 resimden 1. Samsung Epix Motherboard Replacement: adım 5, 2 resimden 2.
      • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
      • There are three clips on each side and two at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Epix Motherboard Replacement: adım 6, 1 resimden 1.
      • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
      • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Epix Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
      • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Epix Motherboard Replacement: adım 8, 1 resimden 1.
      • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Epix Motherboard Replacement: adım 9, 1 resimden 1.
      • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
      • Lift the speaker off of the motherboard.
      • The camera will remain attached to the phone when removing the speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Epix Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
      • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Epix Motherboard Replacement: adım 11, 1 resimden 1.
      • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Epix Motherboard Replacement: adım 12, 2 resimden 1. Samsung Epix Motherboard Replacement: adım 12, 2 resimden 2.
      • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
      • The two disconnected ribbon cables connect to the keypad and center button.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Epix Motherboard Replacement: adım 13, 1 resimden 1.
      • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Epix Motherboard Replacement: adım 14, 1 resimden 1.
      • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Epix Motherboard Replacement: adım 15, 1 resimden 1.
      • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Epix Motherboard Replacement: adım 16, 1 resimden 1.
      • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
      • A ribbon cable is still connected underneath on the right side.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Epix Motherboard Replacement: adım 17, 1 resimden 1.
      • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
      • Remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mark Wyse
62 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G15
5 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 2,003
