Ana içeriğe geç
Samsung Eternity Antenna/Speaker Replacement
Neye ihtiyacın var
    • Remove the back battery cover.
  1. Samsung Eternity Antenna/Speaker Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Antenna/Speaker Replacement: adım 3, 1 resimden 1.
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Antenna/Speaker Replacement: adım 4, 2 resimden 1. Samsung Eternity Antenna/Speaker Replacement: adım 4, 2 resimden 2.
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Antenna/Speaker Replacement, Antenna/Speaker: adım 5, 1 resimden 1.
    • Pop the antenna plug off of its socket with a pair of metal tweezers.
  5. Samsung Eternity Antenna/Speaker Replacement: adım 6, 1 resimden 1.
    • Peel off the Identification sticker.
  6. Samsung Eternity Antenna/Speaker Replacement: adım 7, 1 resimden 1.
    • Peel the button sensor on the side of the motherboard off of the case.
  7. Samsung Eternity Antenna/Speaker Replacement: adım 8, 1 resimden 1.
    • Pop the speaker plug out of its socket.
  8. Samsung Eternity Antenna/Speaker Replacement: adım 9, 1 resimden 1.
    • Pry the antennae/speaker component out of its casing. You need to use a little force to get the piece to pop out.
  9. Samsung Eternity Antenna/Speaker Replacement: adım 10, 1 resimden 1.
    • You will now be able to replace the antenna/speaker module.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Kidd
70 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G11
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,856
