Ana içeriğe geç
Samsung Eternity Camera Replacement
Neye ihtiyacın var
      • Remove the back battery cover.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Eternity Camera Replacement: adım 2, 1 resimden 1.
      • Using a nylon spudger, remove the phone's battery.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Eternity Camera Replacement: adım 3, 1 resimden 1.
      • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Eternity Camera Replacement: adım 4, 2 resimden 1. Samsung Eternity Camera Replacement: adım 4, 2 resimden 2.
      • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Eternity Camera Replacement, Camera: adım 5, 1 resimden 1.
      • Peel off the Identification sticker.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Eternity Camera Replacement: adım 6, 1 resimden 1.
      • Peel the button sensor on the side of the motherboard off of the case.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Eternity Camera Replacement: adım 7, 1 resimden 1.
      • Pop the black hinged-release lever toward its ribbon, then slide the ribbon out.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Eternity Camera Replacement: adım 8, 1 resimden 1.
      • Peel up the camera attachment.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Eternity Camera Replacement: adım 9, 1 resimden 1.
      • You will now be able to replace the Camera component with a new part.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Michelle Haddock
51 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G11
5 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 2,086
