Ana içeriğe geç
Samsung Eternity Microphone Replacement
Neye ihtiyacın var
    • Remove the back battery cover.
  1. Samsung Eternity Microphone Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Microphone Replacement: adım 3, 1 resimden 1.
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Microphone Replacement: adım 4, 2 resimden 1. Samsung Eternity Microphone Replacement: adım 4, 2 resimden 2.
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Microphone Replacement, Motherboard: adım 5, 1 resimden 1.
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Microphone Replacement: adım 6, 3 resimden 1. Samsung Eternity Microphone Replacement: adım 6, 3 resimden 2. Samsung Eternity Microphone Replacement: adım 6, 3 resimden 3.
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Microphone Replacement: adım 7, 1 resimden 1.
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Microphone Replacement: adım 8, 1 resimden 1.
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Microphone Replacement: adım 9, 3 resimden 1. Samsung Eternity Microphone Replacement: adım 9, 3 resimden 2. Samsung Eternity Microphone Replacement: adım 9, 3 resimden 3.
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Microphone Replacement: adım 10, 1 resimden 1.
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: adım 11, 1 resimden 1.
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Microphone Replacement: adım 12, 3 resimden 1. Samsung Eternity Microphone Replacement: adım 12, 3 resimden 2. Samsung Eternity Microphone Replacement: adım 12, 3 resimden 3.
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Microphone Replacement: adım 13, 3 resimden 1. Samsung Eternity Microphone Replacement: adım 13, 3 resimden 2. Samsung Eternity Microphone Replacement: adım 13, 3 resimden 3.
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
  13. Samsung Eternity Microphone Replacement, Microphone: adım 14, 1 resimden 1.
    • Pop the microphone up and out of its small housing.
  14. Samsung Eternity Microphone Replacement: adım 15, 1 resimden 1.
    • Peel up the black tape on the bottom of the back case.
  15. Samsung Eternity Microphone Replacement: adım 16, 1 resimden 1.
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
  16. Samsung Eternity Microphone Replacement: adım 17, 3 resimden 1. Samsung Eternity Microphone Replacement: adım 17, 3 resimden 2. Samsung Eternity Microphone Replacement: adım 17, 3 resimden 3.
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
  17. Samsung Eternity Microphone Replacement: adım 18, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
  18. Samsung Eternity Microphone Replacement: adım 19, 1 resimden 1.
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
  19. Samsung Eternity Microphone Replacement: adım 20, 1 resimden 1.
    • The front button board should slide out. At this time you can replace the button/microphone component.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michelle Haddock
51 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G11
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 40
Her zaman: 2,408
