Ana içeriğe geç
Samsung Eternity Motherboard Replacement
Neye ihtiyacın var
    • Remove the back battery cover.
    FixBot'a Sor
    Yorum Ekle
  1. Samsung Eternity Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger, remove the phone's battery.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Eternity Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Eternity Motherboard Replacement: adım 4, 2 resimden 1. Samsung Eternity Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Eternity Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Eternity Motherboard Replacement: adım 6, 3 resimden 1. Samsung Eternity Motherboard Replacement: adım 6, 3 resimden 2. Samsung Eternity Motherboard Replacement: adım 6, 3 resimden 3.
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Eternity Motherboard Replacement: adım 7, 1 resimden 1.
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Eternity Motherboard Replacement: adım 8, 1 resimden 1.
    • Peel the button sensor on the side of the motherboard off of the case.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Eternity Motherboard Replacement: adım 9, 3 resimden 1. Samsung Eternity Motherboard Replacement: adım 9, 3 resimden 2. Samsung Eternity Motherboard Replacement: adım 9, 3 resimden 3.
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Eternity Motherboard Replacement: adım 10, 1 resimden 1.
    • You have successfully removed the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kevin Huang
11 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G11
5 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 2,623
