Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Evergreen SGH-A667 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: adım 1, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: adım 1, 2 resimden 2.
  2. Samsung Evergreen SGH-A667 Teardown: adım 2, 1 resimden 1.
    • Begin by prying off the rear battery-access panel.
  3. Samsung Evergreen SGH-A667 Teardown: adım 3, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 3, 2 resimden 2.
    • Remove battery pack and SIM card.
    • Remove the seven screws marked in red.
  4. Samsung Evergreen SGH-A667 Teardown: adım 4, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 4, 2 resimden 2.
    • Pry the case away from the body of the phone. Be gentle around the volume control, micro USB, and micro SD ports.
  5. Samsung Evergreen SGH-A667 Teardown: adım 5, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 5, 2 resimden 2.
    • Camera
    • Keyboard ribbon connector
    • Microphone
    • Remove the two screws marked in red to free the EMI shielding.
  6. Samsung Evergreen SGH-A667 Teardown: adım 6, 1 resimden 1.
    • The keyboard ribbon strings each of the pieces together, but the keypad flops right out on its own.
  7. Samsung Evergreen SGH-A667 Teardown: adım 7, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 7, 2 resimden 2.
    • Remove the six screws marked in red; they hold the keyboard to the sliding mechanism.
  8. Samsung Evergreen SGH-A667 Teardown: adım 8, 3 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 8, 3 resimden 2. Samsung Evergreen SGH-A667 Teardown: adım 8, 3 resimden 3.
    • Huzzah the sliding carriage is free—what's that? The funk of forty thousand years? This part of the phone never sees the light of day!
    • Remove the six screws circled in red.
    • Sometimes this screw is hidden by the ribbon cable!
  9. Samsung Evergreen SGH-A667 Teardown: adım 9, 3 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 9, 3 resimden 2. Samsung Evergreen SGH-A667 Teardown: adım 9, 3 resimden 3.
    • More plastic clips means a little more finagling to pry the front case off.
    • The work pays off with a snappy line-up.
  10. Samsung Evergreen SGH-A667 Teardown: adım 10, 2 resimden 1. Samsung Evergreen SGH-A667 Teardown: adım 10, 2 resimden 2.
    • Gently flex the faceplate to loosen the adhesive's hold on the screen.
    • After loosening all edges, begin to peel the LCD from the plastic. When in doubt, stop, look, and listen; just like crossing the street.
  11. Samsung Evergreen SGH-A667 Teardown: adım 11, 1 resimden 1.
    • The sum of its parts
    • Use these steps in reverse to reassemble—a method tried and true!
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 899
