Ana içeriğe geç
Samsung Galaxy A10 Charging Port Replacement
Videoya Genel Bakış
  1. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: adım 1, 3 resimden 1. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: adım 1, 3 resimden 2. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Remove the SIM Tray.
    • Use plastic tools to separate the back cover.
  2. Samsung Galaxy A10 Charging Port Replacement: adım 2, 3 resimden 1. Samsung Galaxy A10 Charging Port Replacement: adım 2, 3 resimden 2. Samsung Galaxy A10 Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove the silver Phillips screws to be able to disassemble the motherboard shields.
  3. Samsung Galaxy A10 Charging Port Replacement: adım 3, 3 resimden 1. Samsung Galaxy A10 Charging Port Replacement: adım 3, 3 resimden 2. Samsung Galaxy A10 Charging Port Replacement: adım 3, 3 resimden 3.
    • Disconnect the battery.
    • Remove the screws and the charging board shield.
  4. Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: adım 4, 2 resimden 1. Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: adım 4, 2 resimden 2.
    • Disconnect the Main flex cable and the coaxial antenna cables and remove the charging board.
  5. Samsung Galaxy A10 Charging Port Replacement: adım 5, 3 resimden 1. Samsung Galaxy A10 Charging Port Replacement: adım 5, 3 resimden 2. Samsung Galaxy A10 Charging Port Replacement: adım 5, 3 resimden 3.
    • Cover the microphone hole to prevent microphone damage.
    • Use hot air to remove the Micro USB connector.
  6. Samsung Galaxy A10 Charging Port Replacement: adım 6, 3 resimden 1. Samsung Galaxy A10 Charging Port Replacement: adım 6, 3 resimden 2. Samsung Galaxy A10 Charging Port Replacement: adım 6, 3 resimden 3.
    • Clean the tin and install the new charging connector.
  7. Samsung Galaxy A10 Charging Port Replacement: adım 7, 2 resimden 1. Samsung Galaxy A10 Charging Port Replacement: adım 7, 2 resimden 2.
    • Clean the board and test the device.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
ZFix
192.056 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.525 adet Kılavuz yazıldı
Bir Yorum
Waste of time unless you're obsessed with soldering. Just buy a complete board. Cheaper, easier and quicker.
[deleted] - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 62
Son 30 gün: 254
Her zaman: 7,751
