Giriş
Prereq for replacing the motherboard cover in your Samsung Galaxy A10.
Neye ihtiyacın var
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I have looked literally everywhere and nobody is covering the top motherboard 2 connectors w/ Ribbons on top the black squares one camera and the 1 to the right how does that 1 to the right connect with the ribbon please help thank you
