Ana içeriğe geç
Samsung Galaxy A11 Display Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: adım 1, 3 resimden 3.
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy A11 Display Assembly Replacement: adım 2, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 2, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy A11 Display Assembly Replacement: adım 3, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 3, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 3, 3 resimden 3.
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy A11 Display Assembly Replacement, Battery: adım 4, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Battery: adım 4, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement, Battery: adım 4, 3 resimden 3.
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy A11 Display Assembly Replacement: adım 5, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 5, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 5, 3 resimden 3.
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy A11 Display Assembly Replacement: adım 6, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 6, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 6, 3 resimden 3.
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: adım 7, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: adım 7, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: adım 7, 3 resimden 3.
    • Gently use tweezers to peel up the copper strip on the top right of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy A11 Display Assembly Replacement: adım 8, 2 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Remove the three black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy A11 Display Assembly Replacement: adım 9, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 9, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 9, 3 resimden 3.
    • Using tweezers, carefully remove the earpiece speaker at the top of the phone.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    • If needed, you can use a hair dryer to apply heat to the speaker and loosen the adhesive.
    • If needed, you may orient the tweezers to your liking, gripping the earpiece horizontally or vertically, while removing it.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: adım 10, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: adım 10, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: adım 10, 3 resimden 3.
    • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
    • Remove the fingerprint sensor from the device.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Galaxy A11 Display Assembly Replacement, Motherboard: adım 11, 1 resimden 1.
    • Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Galaxy A11 Display Assembly Replacement: adım 12, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 12, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 12, 3 resimden 3.
    • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
    • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
    • Lift these cables up slightly to reveal a gap.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Galaxy A11 Display Assembly Replacement: adım 13, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 13, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 13, 3 resimden 3.
    • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
    • If needed, use a metal spudger as a sturdier alternative.
    • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
    • Remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: adım 14, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: adım 14, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: adım 14, 3 resimden 3.
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Galaxy A11 Display Assembly Replacement: adım 15, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 15, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 15, 3 resimden 3.
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Galaxy A11 Display Assembly Replacement: adım 16, 3 resimden 1. Samsung Galaxy A11 Display Assembly Replacement: adım 16, 3 resimden 2. Samsung Galaxy A11 Display Assembly Replacement: adım 16, 3 resimden 3.
    • Using tweezers, gently pry the daughterboard from the device.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: adım 17, 2 resimden 1. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: adım 17, 2 resimden 2.
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Galaxy A11 Display Assembly Replacement, Display Assembly: adım 18, 1 resimden 1.
    • The display assembly is separated from all other components and can be replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chloe Bulloch
789 İtibar
3 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-6, Crenshaw Fall 2024 Utah Tech University, Team 1-6, Crenshaw Fall 2024 üyesi
UTAHTECH-CRENSHAW-F24S1G6
2 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 34
Son 30 gün: 155
Her zaman: 2,611
