Giriş
This is a full screen replacement of the A22/A22 5g please be careful with the disassembly and assembly of the device as it has fragile components
Neye ihtiyacın var
Firstly remove the Sim card .
start heating the back of the phone all around the edges of the back with an iOpener or aheat gun
start moving your pry card start around the edges of the phone to remove the adhesive it will take some time be patient and do it with care
mind the 2 cables in the middle of the phone don't damage them
When you open the back start taking of the screws of the top of the phone and bottom of the frame
Then with a pry card remove the inner plastic frame of the phone carefully go all around the phone to take off the frame
You should remove the wire connected from the frame to the phone
Remove the three ribbon cables for the screen and battery
Remove the speaker cover this will show the ribbon cable you will remove which is connected to the screen
Next remove your old screen with a iOpener or a heat gun and a pry cart go all round the edges to take of the old display
make sure you go all around the edges clean left out adhesive and make sure the front is properly clean
Place the ribbon cable inside the gap of the frame and assemble it
Place your new adhesive around the frame of the phone place your new screen on top of the frame
closed it up and use Clamp holders to press around the whole screen of the phone make sure it sticks in place
Then turn the phone around place the all the ribbon cables back in place make sure your new screen works
close the back cover with new adhesive use clamp Holders to help you completely seal it up
If you don't have clamp holders you can use ruber bands
9 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks for the help
It is not Galaxy A22 5G device on the pics.
Adhesive missing in “Needed parts”
