Ana içeriğe geç
Samsung Galaxy A3 2016 Back Cover Replacement
Neye ihtiyacın var
  1. Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: adım 1, 3 resimden 1. Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: adım 1, 3 resimden 2. Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: adım 1, 3 resimden 3.
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • Lift the bottom part of your back cover with a suction handle and insert an opening pick.
  2. Samsung Galaxy A3 2016 Back Cover Replacement: adım 2, 3 resimden 1. Samsung Galaxy A3 2016 Back Cover Replacement: adım 2, 3 resimden 2. Samsung Galaxy A3 2016 Back Cover Replacement: adım 2, 3 resimden 3.
    • Slide the opening pick up to the rear camera to separate the back cover from the frame.
  3. Samsung Galaxy A3 2016 Back Cover Replacement: adım 3, 2 resimden 1. Samsung Galaxy A3 2016 Back Cover Replacement: adım 3, 2 resimden 2.
    • Insert a second opening pick and move around the other corner at the bottom part of the back cover.
  4. Samsung Galaxy A3 2016 Back Cover Replacement: adım 4, 3 resimden 1. Samsung Galaxy A3 2016 Back Cover Replacement: adım 4, 3 resimden 2. Samsung Galaxy A3 2016 Back Cover Replacement: adım 4, 3 resimden 3.
    • Move the second pick along the left side of the back cover to loosen the adhesive.
    • Move around the upper left corner and loosen the adhesive above the rear camera.
    • After loosening all the edges and sides of the back cover use an iOpener to loosen the adhesive underneath the center of it.
  5. Samsung Galaxy A3 2016 Back Cover Replacement: adım 5, 3 resimden 1. Samsung Galaxy A3 2016 Back Cover Replacement: adım 5, 3 resimden 2. Samsung Galaxy A3 2016 Back Cover Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Insert a plastic card at the bottom and slide it underneath the back cover.
    • Separate the glue until you reach the rear camera.
    • Now you can slowly lift up the back cover and finally remove it.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
231.367 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
1Rehber Yorum
where can I buy the back cover? tnx
rompecolleoni - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 16,989
