Giriş
Use this guide to replace the back cover of your Galaxy A5.
  1. Start by switching off your phone. Take an iOpener to heat up and soften the glue behind the back cover. With a suction handle lift the back cover to insert an opening pick.
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift the back cover to insert an opening pick.
  2. Slide the pick up to the middle to separate the back cover from the frame. Insert a second opening pick and move around the right corner along the bottom and around the left corner. Insert a second opening pick and move around the right corner along the bottom and around the left corner.
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Take another opening pick and continue towards the top corner. Here you want to use one more pick for the last part at the top. Here you want to use one more pick for the last part at the top.
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  5. Insert a plastic card at the bottom and slide it underneath the back cover. Insert a plastic card at the bottom and slide it underneath the back cover. Insert a plastic card at the bottom and slide it underneath the back cover.
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  6. Heat up the back cover once again so you can slide the plastic card towards the top. Always take a peek underneath the back cover to not damage any parts like the NFC antenna. Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Always take a peek underneath the back cover to not damage any parts like the NFC antenna.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
41.637 İtibar
99 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
102 Üyeler
7.937 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 Gün: 250
Son 30 Gün: 1,108
Her zaman: 30,712
