Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Power off your phone before beginning disassembly.
Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Insert an opening pick at the bottom end of your phone.
Start to slide the tip of the opening pick to the bottom left corner and cut the adhesive with it.
Leave the opening pick in the bottom left corner to prevent the adhesive from resealing. Insert a new opening pick and start to cut the adhesive on the left side of the phone.
Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
19 farklı kişi bu kılavuzu tamamladı.
4 Yorum
genial, tutorial paso a paso pregunta cual es el adhesivo que se utiliza ???
Hi Erik, you can buy precut and for the A5 optimized back cover adhesive or the precut adhesive card in our shop.
