Giriş
Use this guide to remove the back cover on your Samsung Galaxy A51.
You’ll need replacement adhesive to reattach the back cover when reassembling the device.
Neye ihtiyacın var
Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
Slide the opening pick to the bottom right corner and leave it there.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
14 farklı kişi bu kılavuzu tamamladı.
