Ana içeriğe geç
Samsung Galaxy A51 Screen with Frame Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy A51 Screen with Frame Replacement, Samsung Galaxy A51 Screen with Frame: adım 1, 2 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement, Samsung Galaxy A51 Screen with Frame: adım 1, 2 resimden 2.
    • Samsung Galaxy A51 - the new spare part.
  2. Samsung Galaxy A51 Screen with Frame Replacement, Back Cover: adım 2, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement, Back Cover: adım 2, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement, Back Cover: adım 2, 3 resimden 3.
    • Warm up the device to soften the adhesive.
    • Use suction cup and plastic tools (playing cards) to separate the back cover.
  3. Samsung Galaxy A51 Screen with Frame Replacement, SIM Tray and screws: adım 3, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement, SIM Tray and screws: adım 3, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement, SIM Tray and screws: adım 3, 3 resimden 3.
    • Remove the SIM Tray.
    • Remove 13x Phillips screws.
  4. Samsung Galaxy A51 Screen with Frame Replacement, Middle Frame removal: adım 4, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement, Middle Frame removal: adım 4, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement, Middle Frame removal: adım 4, 3 resimden 3.
    • Only use plastic tools to separate the metal frame.
  5. Samsung Galaxy A51 Screen with Frame Replacement, Test the new spare part: adım 5, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement, Test the new spare part: adım 5, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement, Test the new spare part: adım 5, 3 resimden 3.
    • Test the new spare part.
  6. Samsung Galaxy A51 Screen with Frame Replacement: adım 6, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement: adım 6, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement: adım 6, 3 resimden 3.
    • Disconnect and remove the main flex cable.
    • To remove the fingerprint sensor - remove two Philips screws and disconnect the flex cable.
    • Disconnect coaxial antenna cable.
  7. Samsung Galaxy A51 Screen with Frame Replacement: adım 7, 3 resimden 1. Samsung Galaxy A51 Screen with Frame Replacement: adım 7, 3 resimden 2. Samsung Galaxy A51 Screen with Frame Replacement: adım 7, 3 resimden 3.
    • Remove the Sub -board? Charging board.
    • The motherboard is secured by one small black screw, remove it to separate the board.
    • Don't forget to transfer the receiver.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
ZFix
191.416 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.474 adet Kılavuz yazıldı
Bir Yorum
Hallo, i made repleacment, display went well ( touch and functions, but after turning on the display was like in shadow and side lines were on white kind a yellow fade, what it could be? is it by bad replacement, display or something else?
Vojtěch Kolář - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 56
Son 30 gün: 308
Her zaman: 10,127
