Ana içeriğe geç
Samsung Galaxy A8(2018) Back Cover Replacement
  1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: adım 1, 2 resimden 1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: adım 1, 2 resimden 2.
    • Turn off your phone.
    • Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
    • The adhesive is distributed over the outline of the back cover shown in red in the photo.
  2. Samsung Galaxy A8(2018) Back Cover Replacement: adım 2, 1 resimden 1.
    • Use a suction cup to lift the back cover and insert an opening pick into the slot created.
    • Start in the middle and cut the adhesive while maintaining tension on the suction cup.
    • If you find it increasingly difficult to move the pick, reheat the iOpener or use a hair dryer.
  3. Samsung Galaxy A8(2018) Back Cover Replacement: adım 3, 2 resimden 1. Samsung Galaxy A8(2018) Back Cover Replacement: adım 3, 2 resimden 2.
    • Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
    • Do not force the cover open. Re-soften the adhesive with an iOpener or hair dryer if the back cover does not come off or begins to warp.
    • On the photo opposite three corners have been released, with one corner remaining to be able to completely remove the glass.
    • Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
  4. Samsung Galaxy A8(2018) Back Cover Replacement: adım 4, 1 resimden 1.
    • Unplug the fingerprint reader with tweezers.
  5. Samsung Galaxy A8(2018) Back Cover Replacement: adım 5, 1 resimden 1.
    • Remove the back cover.
    • Prepare for reassembly by removing the remaining adhesive from the phone with a spudger. Clean the adhesive surfaces with isopropyl alcohol and a lint-free cloth.
Sonuç
To reassemble your device, follow the instructions in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Jerry Wheeler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Jean pierre bourhis
361 İtibar
1 Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
38 Üyeler
241 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 93
Her zaman: 3,785
