Giriş
Follow this guide to replace the display on your Samsung Galaxy A8 (2018). For repairing broken or unresponsive touchscreens, this guide is useful. It takes you through all the necessary steps which will help you change your screen without tampering with the original panel, logic board or battery.
Before beginning the repair, please check that you have all the necessary tools required.
As a precaution, it is recommended that you make a full backup of your data before starting your Galaxy A8 (2018) screen replacement.
Neye ihtiyacın var
Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
Bu adımda kullanılan alet:Plastic Cards$2.99
Using a hairdryer, heat up the back of the device to loosen the adhesive.
Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
To create an opening, insert the opening pick gently between the screen and the chassis
Gently slide the plastic card around the screen to take it off the chassis.
14 farklı kişi bu kılavuzu tamamladı.
