Ana içeriğe geç
Samsung Galaxy A8 (2018) Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy A8  (2018) Display Replacement, Display: adım 1, 1 resimden 1.
    • Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
  2. Samsung Galaxy A8  (2018) Display Replacement: adım 2, 1 resimden 1.
    • Insert the SIM Card Ejection tool into the small hole and remove the SIM Card tray.
  3. Samsung Galaxy A8  (2018) Display Replacement: adım 3, 3 resimden 1. Samsung Galaxy A8  (2018) Display Replacement: adım 3, 3 resimden 2. Samsung Galaxy A8  (2018) Display Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Using a hairdryer, heat up the back of the device to loosen the adhesive.
    • Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
    • Be careful not to overheat the rear glass since it is very fragile.
  4. Samsung Galaxy A8  (2018) Display Replacement: adım 4, 2 resimden 1. Samsung Galaxy A8  (2018) Display Replacement: adım 4, 2 resimden 2.
    • Using a pair of tweezers, disconnect the clip connecting camera and motherboard.
    • Lift the back panel off of the chassis of the device.
  5. Samsung Galaxy A8  (2018) Display Replacement: adım 5, 3 resimden 1. Samsung Galaxy A8  (2018) Display Replacement: adım 5, 3 resimden 2. Samsung Galaxy A8  (2018) Display Replacement: adım 5, 3 resimden 3.
    • Use the P2 Pentalobe screwdriver to remove the 14 (0.8mm) screws.
    • Use the Phillips #0 screwdriver to remove the rest of the four 1.5mm screws.
    • Gently leverage with the spudger under the top antenna to lift it.
    • Continue with the spudger to lift and extract the NFC antenna.
  6. Samsung Galaxy A8  (2018) Display Replacement: adım 6, 3 resimden 1. Samsung Galaxy A8  (2018) Display Replacement: adım 6, 3 resimden 2. Samsung Galaxy A8  (2018) Display Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery using the spudger.
    • Gently lift the speaker and pull it out of the slot.
    • Disconnect the display cables from the device.
  7. Samsung Galaxy A8  (2018) Display Replacement: adım 7, 3 resimden 1. Samsung Galaxy A8  (2018) Display Replacement: adım 7, 3 resimden 2. Samsung Galaxy A8  (2018) Display Replacement: adım 7, 3 resimden 3.
    • To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
    • To create an opening, insert the opening pick gently between the screen and the chassis
    • Gently slide the plastic card around the screen to take it off the chassis.
    • Be careful not to overheat the centre of the display panel as this can damage it.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
My microphone isnt working please help
alpadarkshadow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 174
Her zaman: 9,961
