Ana içeriğe geç
Samsung Galaxy Alpha Back Cover Replacement
  1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: adım 1, 3 resimden 1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: adım 1, 3 resimden 2. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: adım 1, 3 resimden 3.
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
Sonuç
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
13 farklı kişi bu kılavuzu tamamladı.
Sarah
940 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G17
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 3,839
