Ana içeriğe geç
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: adım 1, 3 resimden 1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: adım 1, 3 resimden 2. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: adım 1, 3 resimden 3.
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: adım 2, 2 resimden 1. Samsung Galaxy Alpha microSIM Card Replacement, Battery: adım 2, 2 resimden 2.
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: adım 3, 1 resimden 1.
    • Remove your Micro SIM card from the slot shown.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Tyler
769 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G17
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 2,641
