Ana içeriğe geç
Samsung Galaxy Amp 2 Home Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: adım 1, 2 resimden 2.
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Home Button Replacement: adım 2, 3 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement: adım 2, 3 resimden 2. Samsung Galaxy Amp 2 Home Button Replacement: adım 2, 3 resimden 3.
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: adım 3, 3 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement, Screen: adım 3, 3 resimden 2. Samsung Galaxy Amp 2 Home Button Replacement, Screen: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    $3.99
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Home Button Replacement: adım 4, 1 resimden 1.
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Home Button Replacement: adım 5, 3 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement: adım 5, 3 resimden 2. Samsung Galaxy Amp 2 Home Button Replacement: adım 5, 3 resimden 3.
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: adım 6, 3 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: adım 6, 3 resimden 2. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: adım 6, 3 resimden 3.
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: adım 7, 3 resimden 1. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: adım 7, 3 resimden 2. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: adım 7, 3 resimden 3.
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Nickolatos
430 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Cardinal Summer 2018 UW Tacoma, Team S1-G1, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 44
Her zaman: 764
