Giriş
Repair your broken or damaged screen with this guide. A replacement may be needed if the screen is cracked or unresponsive. This guide recommends use of a heat gun, though a blow dryer can be used instead. Use care when applying heat to the screen and carefully detach delicate wiring to avoid damaging the phone.
Neye ihtiyacın var
Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
Lift upwards and gently pry the rear panel off of the phone.
Bu adımda kullanılan alet:Tweezers$3.99
Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
Disconnect the connector piece from the back panel.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I broke the screen on the same day I bought the phone. I have ordered a new one from ebay. I am going to try to install the screen with LCD digitizer.
I had an amp 2 phone i accidently smashed it with my ps3 controller when I was playing games I smashed it on purpose so is this the way to fix the phone
