Ana içeriğe geç
Samsung Galaxy Amp Prime Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Amp Prime Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Amp Prime Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Before beginning this repair, power off your phone and unplug it from the charger.
    • Use a spudger or your fingernails to pry the back case off, starting at the small slit on the side of the phone.
  2. Samsung Galaxy Amp Prime Battery Replacement: adım 2, 3 resimden 1. Samsung Galaxy Amp Prime Battery Replacement: adım 2, 3 resimden 2. Samsung Galaxy Amp Prime Battery Replacement: adım 2, 3 resimden 3.
    • Insert a spudger or your fingernail in the small space at the bottom right where the battery sits to remove it from the phone.
  3. Samsung Galaxy Amp Prime Battery Replacement: adım 3, 3 resimden 1. Samsung Galaxy Amp Prime Battery Replacement: adım 3, 3 resimden 2. Samsung Galaxy Amp Prime Battery Replacement: adım 3, 3 resimden 3.
    • Align the four gold contacts at the top of the battery with the top of the battery compartment.
    • Slide the replacement battery in so the gold contacts connect with the matching socket.
  4. Samsung Galaxy Amp Prime Battery Replacement: adım 4, 1 resimden 1.
    • Replace the back case of the phone.
  5. Samsung Galaxy Amp Prime Battery Replacement: adım 5, 1 resimden 1.
    • Finally, charge your phone. Once it's charged, power on your phone.
Sonuç
[deleted]
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 143
Her zaman: 1,779
