Ana içeriğe geç
Samsung Galaxy Attain 4G Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Attain 4G Battery Replacement, Placement: adım 1, 1 resimden 1.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: adım 2, 2 resimden 1. Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: adım 2, 2 resimden 2.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: adım 3, 3 resimden 1. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: adım 3, 3 resimden 2. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: adım 3, 3 resimden 3.
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Battery Replacement, Heads Up!: adım 4, 1 resimden 1.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Forester
2.558 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 435
