Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Begin by turn the device over to it's back, with the screen facing down.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  5. Make sure when replacing the battery that the arrow on the bottom is facing down.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Forester
2.312 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 186
