Ana içeriğe geç
Samsung Galaxy Attain 4G Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Attain 4G Front Camera Replacement, Placement: adım 1, 1 resimden 1.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: adım 2, 2 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: adım 2, 2 resimden 2.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: adım 3, 3 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: adım 3, 3 resimden 2. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: adım 3, 3 resimden 3.
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Front Camera Replacement, Heads Up!: adım 4, 1 resimden 1.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Front Camera Replacement, Screw Removal: adım 5, 1 resimden 1.
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Front Camera Replacement, Prying: adım 6, 1 resimden 1.
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Front Camera Replacement, Remove Housing: adım 7, 1 resimden 1.
    • Lift the rear housing from the display assembly.
  8. Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: adım 8, 2 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: adım 8, 2 resimden 2.
    • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
  9. Samsung Galaxy Attain 4G Front Camera Replacement: adım 9, 2 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement: adım 9, 2 resimden 2.
    • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
  10. Samsung Galaxy Attain 4G Front Camera Replacement: adım 10, 1 resimden 1.
    • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
  11. Samsung Galaxy Attain 4G Front Camera Replacement: adım 11, 2 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement: adım 11, 2 resimden 2.
    • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
    • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
  12. Samsung Galaxy Attain 4G Front Camera Replacement: adım 12, 1 resimden 1.
    • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
  13. Samsung Galaxy Attain 4G Front Camera Replacement: adım 13, 2 resimden 1. Samsung Galaxy Attain 4G Front Camera Replacement: adım 13, 2 resimden 2.
    • You have now removed the logic board from the display assembly.
  14. Samsung Galaxy Attain 4G Front Camera Replacement, Front Camera: adım 14, 1 resimden 1.
    • Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
    • Do not pry at the black part, as this will damage the connector on the board.
  15. Samsung Galaxy Attain 4G Front Camera Replacement: adım 15, 1 resimden 1.
    • Carefully pull the camera out of it's connector and set to the side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Josh Forester
2.505 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 340
