Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy Buds Pro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    Son Düşünceler
    • The charging case is very easy to disassemble. Its battery is modular and easy to access and replace.
    • Some force is required to open the Buds, which can lead to some slight cosmetic damage and is a daunting first step for a repair.
    • The Buds are only semi-modular: their main circuit boards are easily accessible and held down with Phillips screws, but their batteries use soldered connections.
    • The Buds' drivers are practically inaccessible, making their eventual replacement tedious at best, but most likely downright destructive.
    Onarılabilirlik Puanı
    3
    Onarılabilirlik 10 üzerinden 3
    (10 en kolay onarılabileni)
Taylor Dixon
67.146 İtibar
94 adet Kılavuz yazıldı
10 Yorum
Samsung making less repairable earbuds: “It’s evolving, just backwards.”
Ethan Zuo - Yanıt
Is dropped one ear bud few times and touch control stopped working one it ..except that everything works fine even the volume control…how to fix it?
Jakub Serafin - Yanıt
I love how easy the case is to take apart, however I cannot seem to locate a replacement battery for the charging case. Any idea where I could locate one?
Trevor Reed - Yanıt
Looks like the Galaxy Watch 46mm battery!
https://www.reichelt.com/de/en/battery-f...
I haven't tried it tho, but will have to soon because my Buds Pro case got water damaged. Thankfully it charges the buds but not the case, so I'll try to replace the battery and see if that helps.
Oscar de León -
Found the one! After disassembling my case I could check the actual part number
https://www.ebay.com/itm/354134695747?ha...
Oscar de León -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 138
Son 30 gün: 531
Her zaman: 24,870
