Ana içeriğe geç
Samsung Galaxy Camera 2 Lens Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: adım 1, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: adım 1, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: adım 1, 3 resimden 3.
    • While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
    • Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
  2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to remove screws listed in step 2. There are a total of six 4mm screws.
  3. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 3, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 3, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 3, 3 resimden 3.
    • With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
    • Once this side is free, gently work your way along the edge, all the way around the camera body.
  4. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 4, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 4, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 4, 3 resimden 3.
    • With the screen freed, gently lay the camera on its face, so that the battery compartment faces up. Use both hands to lift the screen up and away.
    • The screen is still attached to the motherboard by a ribbon cable. Be Gentle as it's very fragile.
  5. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 5, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 5, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 5, 3 resimden 3.
    • With the screen separated from the main chassis, use the plastic opening tool to gently pry the edge of the ribbon cable connector from the motherboard.
  6. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen Separated: adım 6, 1 resimden 1.
    • Now the screen is removed.
    • Set the body aside in a safe place.
  7. Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: adım 7, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: adım 7, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: adım 7, 3 resimden 3.
    • After removing the screen and battery to access to the inside of the camera, take note of the two main assemblies inside-- the lens apparatus and the main motherboard. The lens assembly is on the left hand side.
    • There are three small silver screws (4mm PH00) to remove.
  8. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 8, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 8, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the three screws removed, take note of the two ribbon cables connecting the lens assembly to the main motherboard.
    • Use the tweezers to remove the two green strips of tape protecting the connectors.
    • Use the plastic opening tool to release the black clips locking in the ribbon cables, then use the tweezers to gently pull the ribbon cables away from the main motherboard.
  9. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 9, 3 resimden 1. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 9, 3 resimden 2. Samsung Galaxy Camera 2 Lens Assembly Replacement: adım 9, 3 resimden 3.
    • Now that the screws and ribbon cables have been removed, gently pull the lens assembly up from the the camera and remove it.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Timothy Proto
829 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Lacy Spring 2016 USF Tampa, Team 14-5, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G5
3 Üyeler
13 adet Kılavuz yazıldı
7Kılavuz Yorumları
I followed the instructions to replace the lens. However, the camera will not work. Error message says Warning Camera Failed. What went wrong?
Gary Mason - Yanıt
You have a Mother Board Problem
janotrek -
i have dust inside the lenses , how do i open the lens only?
Myra Arcadia - Yanıt
If you don't place the ribbon on the lenses right you can get that error too
Mark brad -
The instructions are fine, as far as they go, which isn't nearly far enough. A much more thorough tutorial - with several key steps that are missing from these instructions, can be found at https://www.youtube.com/watch?v=qpExoJua.... I wouldn't have been able to complete the installation correctly without this helpful video.
David - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 37
Her zaman: 4,991
