Ana içeriğe geç
Samsung Galaxy Camera 2 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Camera 2 Motherboard Replacement, Screen: adım 1, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement, Screen: adım 1, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement, Screen: adım 1, 3 resimden 3.
    • While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
    • Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
  2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to remove screws listed in step 2. There are a total of six 4mm screws.
  3. Samsung Galaxy Camera 2 Motherboard Replacement: adım 3, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 3, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 3, 3 resimden 3.
    • With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
    • Once this side is free, gently work your way along the edge, all the way around the camera body.
  4. Samsung Galaxy Camera 2 Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 4, 3 resimden 3.
    • With the screen freed, gently lay the camera on its face, so that the battery compartment faces up. Use both hands to lift the screen up and away.
    • The screen is still attached to the motherboard by a ribbon cable. Be Gentle as it's very fragile.
  5. Samsung Galaxy Camera 2 Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 5, 3 resimden 3.
    • With the screen separated from the main chassis, use the plastic opening tool to gently pry the edge of the ribbon cable connector from the motherboard.
  6. Samsung Galaxy Camera 2 Motherboard Replacement, Screen Separated: adım 6, 1 resimden 1.
    • Now the screen is removed.
    • Set the body aside in a safe place.
  7. Samsung Galaxy Camera 2 Motherboard Replacement, Lens Assembly: adım 7, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement, Lens Assembly: adım 7, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement, Lens Assembly: adım 7, 3 resimden 3.
    • After removing the screen and battery to access to the inside of the camera, take note of the two main assemblies inside-- the lens apparatus and the main motherboard. The lens assembly is on the left hand side.
    • There are three small silver screws (4mm PH00) to remove.
  8. Samsung Galaxy Camera 2 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the three screws removed, take note of the two ribbon cables connecting the lens assembly to the main motherboard.
    • Use the tweezers to remove the two green strips of tape protecting the connectors.
    • Use the plastic opening tool to release the black clips locking in the ribbon cables, then use the tweezers to gently pull the ribbon cables away from the main motherboard.
  9. Samsung Galaxy Camera 2 Motherboard Replacement: adım 9, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 9, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 9, 3 resimden 3.
    • Now that the screws and ribbon cables have been removed, gently pull the lens assembly up from the the camera and remove it.
  10. Samsung Galaxy Camera 2 Motherboard Replacement, Motherboard: adım 10, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement, Motherboard: adım 10, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement, Motherboard: adım 10, 3 resimden 3.
    • Now that you've removed the battery, screen, and lens assembly, you are ready to continue inremoving the motherboard.
    • There are small ribbon cables connected to the motherboard. Use your plastic opening tool and gently pry the sides of the connectors away from the motherboard. Tuck them away to prevent damaging them when removing the motherboard.
  11. Samsung Galaxy Camera 2 Motherboard Replacement: adım 11, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 11, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 11, 3 resimden 3.
    • After removing the ribbon cables, take note of the screws holding the motherboard into the main chassis of the camera.
    • There are two types of screws to remove. The four (2mm, PH00) circled in red have a fat head, and go in the gold contact.
    • The three (4mm, PH00) screws marked in green have a skinny head.
    • Use the IFIXIT screwdriver and PH0 bit to remove all the screws holding the motherboard.
  12. Samsung Galaxy Camera 2 Motherboard Replacement: adım 12, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 12, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 12, 3 resimden 3.
    • With all the screws removed, use the plastic opening tool to gently pry the headphone jack away from its casing. That jack holds the motherboard in place.
    • Next, gently slide the plastic opening tool underneath the motherboard. Move your fingers underneath and use your hands to completely remove it.
  13. Samsung Galaxy Camera 2 Motherboard Replacement: adım 13, 3 resimden 1. Samsung Galaxy Camera 2 Motherboard Replacement: adım 13, 3 resimden 2. Samsung Galaxy Camera 2 Motherboard Replacement: adım 13, 3 resimden 3.
    • Now, remove the motherboard completely from the chassis.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Sofia Isern
514 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Lacy Spring 2016 USF Tampa, Team 14-5, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G5
3 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
Were do I buy the mother board,I sent my camera to Samsung repaair shop in Jersey,they say part is not available,did not say what part,since sent camera back after 3 calls to ask for it
Jose Forjan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 1,661
