Ana içeriğe geç
Samsung Galaxy Camera Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Camera Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: adım 2, 1 resimden 1.
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: adım 3, 2 resimden 1. Samsung Galaxy Camera Battery Replacement: adım 3, 2 resimden 2.
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: adım 4, 2 resimden 1. Samsung Galaxy Camera Battery Replacement: adım 4, 2 resimden 2.
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
Sonuç
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8 farklı kişi bu kılavuzu tamamladı.
Derek Brown
168 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 119
Her zaman: 2,121
