Ana içeriğe geç
Samsung Galaxy Camera Lens or Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: adım 1, 1 resimden 1.
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 3, 2 resimden 2.
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 4, 3 resimden 3.
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 5, 2 resimden 2.
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 8, 2 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 9, 3 resimden 1. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 9, 3 resimden 2. Samsung Galaxy Camera Lens or Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Keith Lipking
386 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
Would love a video of this, as well.
David CrossmN - Yanıt
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 3,565
