Ana içeriğe geç
Samsung Galaxy Centura Camera Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Centura Camera Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Centura Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Locate the rectangular groove on the top side of the device.
      • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Centura Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy Centura Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy Centura Camera Replacement: adım 2, 3 resimden 3.
      • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
      • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Centura Camera Replacement, Camera: adım 3, 1 resimden 1.
      • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Centura Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Centura Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Centura Camera Replacement: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the three metal clips holding the camera in place, and pull these clips away from the camera using the tweezers.
      • Use the tweezers to lift the camera out of the plastic housing. It should come free without resistance.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Austin Erickson
360 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G5
3 Üyeler
55 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 531
